Further information:
Damaged Case
Unfortunately the case was damaged and I bought as it was from UK. CD player works flawlessly and no issues.
TDA1541
I bought this player to source a TDA1541A S1 chip. Original dac chip has taken out and resocketted with standard TDA1541. Check photo. If you don’t need standard TDA1541 then let me know. Check photo.
The upper part of the case is dented on the front right corner.  This is causing the plastic film of fascia panel not to sit flat and the film has marked as it popped put of place.  The separate lower plate which all the electronics are mounted on seems to be undamaged.  The mains lead was also damaged so it was trimmed it to the undamaged remaining length. The remaining cable is now approximately 40cm long.  No isolation feet.
The original Naim NA-22 DIN Input Cable is included in the sale. No remote. I am using Logitech Harmony to test functionality.
Photos:
PLEASE READ
Edited by SumonKabir
